Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 missfire at idle in gear
  #18 (permalink)
Old 10-06-2012, 08:27 AM
cdminter59 cdminter59 is offline
Originally Posted by ragee517 View Post
Now it has a knocking or pinging like sound above high idle it doies not do it at low idle or at high idle but about 1500 rpm it starts making noise. Oil pressure is above 80 psi at that rpm so its not an issue with oil not being circulated around. could it be my fuel pump going bad. the pump is mechanical and probably has 155,00 miles on it like the stock 305 had.
What weight oil are you using? All you need is a good brand of 10W40 oil and a good oil filter (do not use Fram). Get a stethascope from the auto parts store so you can find out exactly where the ticking is coming from. Why would you install a fuel pump with that many miles on it on a rebuilt motor.
