Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 350 missfire at idle in gear
  #20 (permalink)
Old 10-07-2012, 06:26 AM
ragee517 ragee517 is offline
hey monte
The issue with mine and the rattle that I had was all the rods were tight but not to proper torque specs. So I had to take the oil pan off and tighten all the rods and noise was gone. Not sure if yours is the same problem or not but it sounds similar in what u explain. It only cost 8 dollars to check it out
