I had short block done by local machine shop {wham race engines} have not pulled heads yet double checking cheaper fixes first. Engine has about 200 miles on build-up. Noise started within last 5 miles checked all lifters,pushrods,rockers,accesories,transmission,f uel pump,fuel pump rod,distributor,valve springs, and headers.
Pulled engine and did a visual look at bottom end did not see any problems took oil and filter back to machine shop to have builder look at filter and check oil. The owner cut filter open and said filter looked normal for first filter and oil (second oil change) looked normal except running rich, probably from alot of idle time looking for problem.
