SBC 350 New Engine Trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2012, 06:30 PM
98 Chevy K1500
5.7 350 vortec .30 over
comp cams 08-300-8 (grind cs 262h-r12)
duration at .050 206(intake) and 210(exhaust)
Recent engine and Trans Overhaul
Finally got the timing figured out on this beast. Truck is driving.
Here are the new issues...
  1. Hard crank at start.. wrrrrr, wrrrrrr, wrr,wrrr,>> then it will fire.
  2. Seems worse when hot.
  3. Replaced starter to brand new and starts faster but still the same issue.
  4. Idle seems to fall too low when at a stop light or something and will die if I don't keep the rpm up to about 900.
Are these issues related. This is my first motor build and I feel like it could be the valve adjustment.. maybe too tight??
I'm also still on the fence as to whether or not I need my PCM re-flashed and maybe that this is causing the problems.
Old 12-12-2012, 06:42 PM
Originally Posted by abbazabba View Post
98 Chevy K1500
You can get off the fence now; count on this needing to be done.
Bogie
Old 12-12-2012, 07:43 PM
Do you feel like that is the cause of most of these symptoms?
Anyone you would recommend for a re-flash?
Old 12-12-2012, 08:16 PM
Banned
new fuel filter and test for fuel pressure.. and how long it takes to get up to pressure as you crank..
weak pump and /or low voltage at idle can cause this.. or just a dirty fuel filter
Old 12-12-2012, 09:11 PM
The filter is new.. Pump though could be going.
The fuel gauge has always been virtually unreadable so maybe the pump would fix this too. The gauge would flap between full and empty
350 SBC engine dodgewade Hotrodding Basics 2 02-07-2011 07:26 PM
sbc 350 timing trouble shahova1 Engine 18 01-08-2011 08:13 AM
350 Chevy Issues engine trouble... Please help me! ineedspeed Engine 26 07-28-2008 04:23 AM
sbc 350 Timing trouble James7777 Engine 1 10-24-2007 06:07 PM
sbc 350 engine 63impala Engine 2 08-19-2007 04:10 PM
