SBC 350 operating temps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2008, 04:23 PM
What is the safe upper limit for a sbc ? At what temp do they generally give the best performance ?
Old 03-14-2008, 04:42 PM
dawg's Avatar
NAVY VETERAN
I run a 180 degree thermostat and it seems to really like that.
any lower and youll start building sludge
Old 03-14-2008, 05:56 PM
The reason I ask is I run a 165 thermostat and it usually runs in the 185 range until I start Floggin it hard then it will heat up to 205 , I dont let it get any hotter than that . It will not sit in the desert heat and idle without going out of my comfort zone of 205 so I wont sit in traffic in summer .
Just wondering how far past this is safe ?
Old 03-14-2008, 06:08 PM
gm operating temp
oem thermostats are set to open at 195-205 degrees, but you can safely run the motor up to 245 degrees with no problems. it will run its best at about 210
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 03:22 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
