Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc 350 piston rings?
  #16 (permalink)
Old 01-18-2013, 04:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by bwomp969 View Post
my engines over bored 0.60"... ...overbore size 0.45" or 0.65" not 0.60"...
Not to nit pick- and I know what you are saying- but for your own benefit, get the decimal places correct. You mean to type 0.060", 0.045", etc.
...would work except that the pistons I got are meant for 11:1 c/r and the rings are meant for 10.5 to 1 c/r...
There is- generally speaking- no difference in the rings used between these different those two compression ratios.
Now, there may be a different ring called for if the engine will be run at an exceptionally high rpm (generally thinner), and sometimes they'll be made from a different material (if nitrous or super-/turbocharging is to be used), and there are different ring tensions used for different applications, but generally rings will be the same regardless of the CR, all else being equal.
