sbc 350 popping out exhaust through out rpms - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2011, 08:02 PM
prettyboyced's Avatar
i have a vortec 350 xe 274 long tube headers street hire ignition box auto lite 605 plugs gap at .045 accel wires 600 1405 edelbrock car primary .104 .070x.042 sec.110 from 2K and up it pops out the exhaust but not real bad timing set at 18 initial and 32 total
Old 07-10-2011, 12:17 AM
And If I hold it a at certain rpm you can feel it popping could this be a lean misfire
Old 07-10-2011, 01:25 AM
B.A.M.F
could be a serious exhaust leak at the manifold flange, in my race car i had an issue similar to this with open full length headers major diff was the fuel vapors in the tubes would catch fire this happened because the bolts holding the headers up were walking out
Old 07-10-2011, 06:33 AM
GMC boogie's Avatar
Sounds ignition related, I would start with the Accel wires, never had much luck with thier stuff.
Old 07-10-2011, 10:41 AM
I put locktite on the collector bolts and tighten them with an impact so they on there pretty good I was thinking I'm running lean on the primaries because at wot it's runs great with no popping
Old 07-10-2011, 10:51 AM
dklong's Avatar
I'm the same as gmc boogie. never had good luck with accel ignition stuff, also run AC - DELCO plugs in a Chevy
Old 07-10-2011, 11:18 AM
cool rockin daddy's Avatar
Why is your total timing so low? Only 32 degrees?
Old 07-10-2011, 11:40 AM
Vortec heads
Old 07-14-2011, 06:10 PM
Could this be a fuel problem because it only happen at cruise which only on the primaries and doesn't happen on wot
Old 07-14-2011, 06:38 PM
bigdog7373's Avatar
Of course it's fast
I would've said timing too advanced. But 32* isnt much. What's your compression?
Old 07-14-2011, 06:54 PM
9.7:1 and I tried playing with timing and if it was an exhaust would it pop on WOT
Old 07-14-2011, 07:06 PM
bigdog7373's Avatar
Of course it's fast
Could be a overly rich mixture. Not burning completely, and combusting in the headers.
Old 07-14-2011, 07:11 PM
That's could be y it doesn't pop when I'm at wot
Old 07-14-2011, 10:59 PM
Again, why such low timing?
Old 07-15-2011, 01:06 AM
DoubleVision's Avatar
By all means, get the timing on spec, it`s not going to run right until you do.
Next is there could be some crossed spark plug wires, very common occurance. If everything checks out okay and you get the timing in spec and the problem persists, pop the valve covers and fire it up, at idle look for a rocker arm or several rocker arms that aren`t doing anything, if you find such, then you have a bum cam.
popping out the exhaust Sagacious Engine 13 12-02-2006 06:28 AM
popping out the exhaust mkclat Engine 9 08-28-2006 09:35 AM
popping in exhaust DS1784 Engine 7 03-16-2005 12:20 PM
exhaust popping dubie Engine 22 07-02-2004 04:41 PM
Pontiac 406 popping above 4000 RPMs HotRodF100 Engine 10 04-21-2002 11:13 PM
