Sbc 350 Questions on Machining - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 09:22 PM
OK so today i was removing my dowel pins because i received this block for free and i deglazed it with a nice crosshatch i believe. my problem is i gouged the deck and i know im going to need it decked and decking is a good idea anyway when shooting for a 400+hp build but im so disappointed i screwed this up. plus another dowel pin i had to push through then drill it out because it wouldn't come out for the life of me. now the dowel pin wont even fit in the whole right... is my block totally junked. Help me out guys.
Tucci
ID:	72276   Click image for larger version
ID:	72277   Click image for larger version
Old 03-13-2013, 10:45 PM
the circular scoring doesn't appear that terribly deep, depending on your piston pin height, you'll probably be ok. i would be concerned about what looks like might be cracks coming from the dowel pin hole outward in the last picture.
Old 03-13-2013, 10:49 PM
ya i don't know because the gouge or whatever goes right in the the steam hole. but the dowel pin i had to drill out look cracked around it cause i accidently indented it with a screwdriver. i feel like a complete moron oh well at least i learn from it. because of the power i want to make im going to have it decked anyway and all necessary machining done. just disappointed in myself.
Old 03-13-2013, 11:40 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
If the hole is going to need to be re-welded and machined,that potentially could get expensive.Those Scotch bright gasket removal disc in a air cut-off tool is misleading.I have them and rarely every use them.Maybe on a occasion on a slightly rusted patch panel for rust repair.I am confused why you didn't leave the pins alone to have the machine shop doing the decking to remove.
I'm sure you realize by now,but just in case,Never on any aluminum heads.
Old 03-13-2013, 11:42 PM
BOBCRMAN@aol.com's Avatar
The scratches are not in a critical area and will not bother gasket seal. Lightly run a sharp file over it once to remove any high area and run it.
The guide pin can be tightened up with a home made knurl. Lay a piece of hardware store rod on a vise and deform the very end with a sharp chisel. Make a cris cross angle pattern/ Then cut it to length and install it in block. Works every time.
Old 03-13-2013, 11:53 PM
1Gary's Avatar
Yeah Bob,if it's not cracked in the hole.I like a finished deck after decking to be somewhat ruff so the head gasket has something to grab too.But given what was done already,not sure with this O/P I would suggest flat hand filing(Sorry G/F,I'm just trying to help out). Might be a good time to get a trusted machine shop involved.
He if worried about SCR/DCR's could still set it at .010 down.
Old 03-14-2013, 11:18 AM
Thanks a lot guys. I love this forum. Guess ill have too see how much all this is going to cost guess it might be worth just buying the summit bare block bored .030 over already with it ready to be assembled already for 700$$$ just wish I could find a sbc 400 can't find any anywhere.
Old 03-14-2013, 11:40 AM
1Gary's Avatar
You want the machine shop that is doing the bore to have the pistons to be used in hand for a final bore size.So I think really to have a bored block in advance of that isn't any advantage at all.
If you have to replace this block,there are a boat load at pick and pulls of L31 truck engines from the yrs 1996 to 2000.There are alot of advantages to using them and not the least of which is they are roller blocks.
SBC Approximate Machining Costs prostcelica Hotrodding Basics 5 12-28-2012 03:15 PM
general machining tolerance question (not just automotive based machining) lowROLLERchevy General Rodding Tech 9 12-28-2007 11:33 AM
350 sbc questions Mortify Engine 18 09-25-2006 05:12 PM
Questions about the SBC 350 Mekolog Engine 2 04-11-2006 12:41 AM
Machining a SBC 327 GIJoe4500 Engine 13 03-28-2006 08:11 PM
