sbc 350 stock heads!! help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2003, 10:32 PM
im wandering if i can make sick heads out of stock heads?if i can what could i do with them?budget is tight! and i cant really afford to go out n spend a g on heads!but i can afford to get sum used stock heads to fix up. im lookin to match them up with 350 bored .30 over, dome pistons n high performance cam.what can i do to sum stock heads for resonable cash n be happy? tu inkfixer
Old 08-12-2003, 10:39 PM
DoubleVision's Avatar
what`s the casting numbers? just give the last 3 digits, that`s all we need.
Old 08-12-2003, 10:41 PM
i havent found any heads yet i wanted to find out if it was possible to high pro stock heads then i will start my search for heads!!
Old 08-12-2003, 11:50 PM
NorthStar's Avatar
Streetable or a race car?
For an engine that has to run on 92 octane you cant go past about 9.5 to 1 compression. So for a street motor that would rule out your domed pistons with pretty much any stock head available.
Does this thing exist yet?
