SBC 350 suddenly started running horrible - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2009, 01:09 PM
hey guys, So i got my 1980-85 crate 350 completely factory with an edelbrock carb. I got it in my 84 jeep CJ7 and have been driving it for the past couple of months, I only put about 600 miles on it so far and drove it to work last week. It drove fine all the way there, well that after noon, it wouldnt idle at all, and wouldnt run under 1000 RPM, now it surges, spudders, and runs very rough under 1500 RPM. and even if its runnin horrible and barely idleing, if you mash the gas its VERY responsive and runs GREAT over 1500. So i changed the fuel filter, and still nothing. I rebuilt and cleaned the carb about 300 miles back, so i dont think its that. but could my timing have changed some how or somethin?? please help, this is getting very aggrivating and completely PISSING ME OFF !!! lol THanks.
Old 06-27-2009, 01:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is your distributer loose? did you check for proper fuel in the carb could be a weak pump. Cole
Old 06-27-2009, 01:54 PM
ya man, Dist. is tight, carb apears to be working fine, fuel pump and reg. are working properly, and correct fuel pressure. Im about ready to roll it off a cliff !!
Old 06-27-2009, 04:04 PM
Definitely sounds like a fuel delivery problem. May want to check the sock in fuel tank.
Old 06-27-2009, 04:11 PM
dont have a filter in the tank, Its a new polly tank, new sender, new fuel lines, new pump, new filter, new everything. i keep thinkin the same thing, but i checked and checked and re checked all the fuel system... and its dead on everytime. im runnin out of things to check. I even checked for oil/gas in the radiator, water in the exhaust, gas or water in the oil, and once again... nothing !!! no vac. leaks or carb problems. i dont know what to do with it anymore, we've been messin with it for about 4 days now, and cant turn anything up.
Old 06-27-2009, 04:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Water in gas? Any chance it was tampered with, at work?
Recheck timing, also reset idle mixture screws. Be sure there's nothing plugging up the idle air bleeds.
Old 06-27-2009, 06:09 PM
Last journal entry: 454
Check for trash in the carb. That will make it idle real bad and want to shut off.
Old 06-27-2009, 06:28 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
It's funny how it happened during the heat of the day. I would check for a 'cracked' vacuum hose, or a vacuum advance chamber, that went 'north' for the summer.
Old 06-27-2009, 09:50 PM
check for vacum leaks.
Old 06-27-2009, 10:03 PM
hey guys thanks for all the replys. upon closer inspections i noticed 2 of my plug wires were kinda melting away. (im runnin block hugger headers... a major pain in the butt) so i changed all the plug wires... still same problem. I pumped about 2 gallons of gas into a 5 gallon bucket and checked for anything, didnt look like water or nothing. I thought it was the heat and humidity when it first happened, since it was so sudden, I live in SW Louisiana, and the past week as been 100-103 degreese and rediculous humidity. but after everything i tried.. i dont know what it it. I guess ill do what all of yall say to do. Ill jus pull the carb all apart and do a cleanin job..again... and look for leaks everywhere. its just a frustrating situation now... but anymore help would be greatly appreciated. Thanks everyone
Old 06-27-2009, 10:15 PM
001mustang's Avatar
Have you pulled the plugs?
What color are the plugs?
Have you pulled one plug wire at a time to make sure all plugs are firing?
Have you verified vac adv diaphragm is working?
Is engine responsive to idle lean/rich screw?
Does it misbehave when engine is cool?
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 09:48 PM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
wrist pin troubleshooting sbc 350 1984stepside Engine 3 07-06-2007 05:30 PM
High flow water pump for SBC 350 75gmck25 Engine 7 05-22-2007 03:42 PM
Need help -- SBC running rich all of a sudden jodz Engine 6 09-05-2003 08:59 AM
