SBC 350 Ticking - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 07:39 PM
SBC 350 Ticking
I have a 1972 scout II with a 69 corvette small block. I was "rebuilt" buy the previous owner.
I have been trying to track down a ticking problem that comes and goes usually when warm
It looks like the lifter arms were re-used, I am not sure if this is common practice.
Here pictures of what I have found so far. Should these be replaced? the guide plate is scored would this cause a ticking sound?
Any help would be greatly appreciated
Old 12-18-2010, 08:48 PM
those scores are supposed to be there. they are oil slots.. they help oil flow around the rocker balls.
run the lash.. make sure they're all done properly.. I REALLY prefer to do mine with the engine running.. it's a little messy, but I've had better luck getting things right
if it still ticks, you might have a lifter that's going bad, or it could be a rod bearing on it's way.. use an automotive stethescope and listen.. a fuel pump can tick like a sun of a gun too.. so can a leaking exhaust manifold/header
Old 12-18-2010, 08:56 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by 1972scoutII
It was "rebuilt" buy the previous owner.
That's why I don't buy anything "rebuilt". If I'm going to need a motor, I buy a core and rebuild it myself. Those rockers and balls have been in there since they were installed on the assembly line at the factory. They'll still work for a light duty motor, but their best days are behind them.
Old 12-18-2010, 09:00 PM
Wiki Edits: 326
Go to the boneyard and purchase two old valve covers. Cut the tops out of them, bolt them on and adjust valves without the mess. Make the part that you cut out just wide enough to get your socket through.
So can a cracked flexplate....
Old 12-18-2010, 09:49 PM
The rebuilt motor came with the truck so I didnt have much of choice.
I just replaced the flexplate thinking that was the problem
All of the rocker balls do not have that groove so that is why I was confused
I plan on replacing the rocker arms, but I was wondering if that could actually be my problem
Old 12-18-2010, 11:09 PM
I've already done that i had a pair of old crappy rusty 'chrome' valve covers that were ideal candidates to become 'sacrificial'
Old 12-19-2010, 02:14 PM
The story unfolds
Looks like one of the lifter studs is sawed and 1/3 through
Any idea what causes this.
My current plan of action is to get new rockers, and pushrods.
But I also need to replace the stud, so I might as well do threaded studs.
Can this be done with the heads installed on the motor?
Old 12-19-2010, 09:52 PM
Thanks for all the responses
So here is the plan
New rockers, nuts, and push rods
Use this tool to pull the studs and the as a guide for the tap
Proform 66783 Proform Rocker Stud Puller and Tap
Use Pioneer studs, these those dont require a jam nut
SCREW-IN 3/8"-24 X 7/16-14 BASE
RM-348-16-PIONEER-ROCKER ARM STUD
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 sbc pistons Thumpr Engine 5 09-08-2009 05:02 PM
are sbc 350 gaskets sets the same despite the year and/or if its a vortec??? Rod stalker Engine 4 08-17-2009 05:44 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
