sbc 350 timing trouble
Ok I have a sbc 350 and the car backfires when you revve the engine up only when its cold but it runs pretty nornal when its hot. But my problem is I put the motor at tdc and the rotor is pointing at the #2 cylinder instead of the #1 cylinder. I read countless of threads and need to know do I have to pull the hei distributor out and put it back in correctly?
Thanks that helps out. The choke is operating last time I checked. I will mess with the idler screw on the carb to see if it gets any better
If its running lean does that cause the car to stall out and act like it wants to cut off when taking off
I recommend to pull it and once you reset it get the rotor at approx 5 o'clock when on verified TDC on #1 clyinder. Mark your dist base so that the mark lines up with the #1 tower on the cap, drop it in and see if it will engage the pump shaft. I use an old (clean) HEI with the cam gear ground down and the rotor plate removed to move the oil pump shaft. You want some room for the dist to spin before the vacuum can hits something either way once the dist is dropped in.
TJ |
Okay but I think b4 I take it out I'm gonna make sure my timing marks are lined up correctly at
Yes a lean condition can do that,,,
This might be a silly question but how do I know if its actually running lean or not
well generally speaking,,,a lean motor will run hotter, ping, stumble, back fire
a retarded timing motor can also run hotter, stumble, back fire a common cause related to both is a vacuum/manifold leak a wide band AF meter/sensor is one tool but if not on hand then the best way is to start with the basics, fuel pressure, carb setup, timing this is general info, list the details of the motor, induction type, stock or modified etc etc. |
350 motor all stock just aftermarket edelbrock intake manifold and edelbrock 600 carb with the fuel pressure at 13 psi
the eddy wants 5.5psi no more,,,are you sure you checked that with a good gage?
I have a fuel pressure gauge on the fuel line b4 it goes thru the carb and the psi is always in between 10-13 psi.
something is amiss, what type of fuel pump is this?
Um idk I just bought the car so I have no idea what fuel pump is on the car
You think the problem is too much fuel going in and its bogging out
| 65 chevy timing trouble | SonnyFaust | Engine | 3 | 06-14-2009 12:03 PM |
| sbc 350 Timing trouble | James7777 | Engine | 1 | 10-24-2007 06:07 PM |
| Help,,,,timing Mark Trouble On A 400 Sbc | tiresmoke55 | Engine | 1 | 11-18-2006 12:35 AM |
| Timing Trouble 350 TBI | Raul_Chile | Electrical | 6 | 03-15-2005 08:57 PM |
| timing trouble | CARGUY | Engine | 7 | 07-22-2002 06:21 PM |
