SBC 350 troubleshoot - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 10:50 AM
Ok guys after finding tdc and reinstall dist car runs good ...then turn car off and it goes from good to worse with each attempt ....also a notable slapping sound start occurring during crank process ....but again this is only after a perfect start now if I pull dist and redo tdc process this thing will start and run perfect ....until I turn it off that is
Old 03-31-2012, 12:52 PM
Ok guys just noticed that the rotor head isn't synced with terminal post anymore after attempting to start .....I take dist off and adjust to perfection then tighten the hold down clamp but still it is always off when I pull cap off any ideas
Old 03-31-2012, 02:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm not 100% I'm understanding you, but it sounds as though the roll pin that holds the gear on the bottom of the distributor shaft may be sheared. This will allow the gear to get out of phase, but could be on there tight enough to run the engine most of the time.
I'd check it by pulling the distributor and seeing if the gear will turn on the shaft with the mechanical advance at the top held stationary. It may take a rag wrapped around the gear to protect it and a pair of channel locks, etc. to turn it.
Old 03-31-2012, 04:22 PM
Thanks cobalt ima check that ...when you say hold the mechanical advance while turning gear....do you mean the rotor
Old 03-31-2012, 08:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Remove the rotor and hold the "ears" the rotor is screwed to. That way the rotor doesn't get cracked or broken in the process.
If you can get to the distributor good enough you really don't have to remove it, just twist it w/the distributor in the engine. If there's not good enough access you'll need to take it out.
Old 03-31-2012, 11:32 PM
Hattie sounds like we having same problem ....see above maybe your rotor and dist is out of sync same as mine
350 tbi troubleshoot sluggish stumped32 Engine 8 01-16-2011 03:55 PM
Speedometer Troubleshoot Cyberats Electrical 6 11-20-2008 08:13 PM
Anyone want to help troubleshoot this engine? Slickriffs Engine 19 08-23-2008 10:32 PM
help me troubleshoot some wiring? Bill-E-BoB Electrical 20 09-09-2007 06:42 PM
help me troubleshoot - warning crappy k car! dh79 Engine 1 10-07-2005 05:32 PM
