SBC 350 Tuned port info - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2008, 04:27 PM
31 five window
Last journal entry: grill and rear end
I need help. I have built many engines but never fuel injected.The short block I have is 5.7 LG ,10243880 it is a 1998 with dish pistons factory stock. I picked up these heads off a crate mexico motor 33417369 and 76cc. I would like to know what compression ratio it should be with these heads. I also have a tuned port set up.I need to know about using the mass or map sensor and what wire harness is best and what cam I can put for good low end street performance.And what injectors.Any other info I need please tell me. Thanks to anybody that has experience with this or at least can tell me compression ratio.
Old 01-23-2008, 05:55 PM
life is a temporary assignment
Call Mr.Mark at street & performance.They will be glad to tell you all you need to know.
Old 01-23-2008, 06:59 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
33417369 is your number. They are 76cc smoggers. With dished pistons you're looking at abyssmally low compression, like possibly in the 7.5:1 range. I'd go with better heads.
Old 01-23-2008, 08:09 PM
31 five window
Thanks, It is that they only have 14,000 miles since new and they where free. How much difference would flat top pistons make with same heads?
Old 01-23-2008, 08:28 PM
About half a point.
Old 01-23-2008, 08:34 PM
31 five window
Guess I will just buy a rotating assembly and build a 383.Thanks everybody.
Old 01-23-2008, 08:55 PM
curtis73's Avatar
Wiki Edits: 16
Well, that's up to you, but some 64cc heads like vortecs would make a very decent compression and a killer street motor. The TPI won't work with vortecs, but there are lots of 64cc traditional heads that will.
Old 01-23-2008, 09:51 PM
HawkZ28's Avatar
I know Victoria's secret....
http://www.sdparts.com/product/12498...Baseplate.aspx
Here you go....slap on some Vortecs and this intake....
Old 01-24-2008, 06:09 AM
31 five window
Thanks for the intake info and the vortec head info. Sounds like a plan. Now could anybody tell me what compression I would have and some details off running the tunned port?
Old 01-24-2008, 01:09 PM
curtis73's Avatar
Wiki Edits: 16
How much dish on the pistons?
Old 01-24-2008, 01:27 PM
31 five window
Dish is .063 with double eye brows.
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 09:48 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
Tuned Port Info jpspridd Engine 1 08-03-2002 03:31 PM
