Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc 350 w/ 305 heads..
Old 05-24-2012, 02:58 PM
kingofny1997 kingofny1997 is offline
Originally Posted by F-BIRD'88
The cams I pointed to for you are not rough idle cams.
The idle is very tame and they work with a stock torque
converter. More power than your choices.
Howards has very similar equal cams at good prices too.
I like Howards cams
. have a look
Yes your milder cam choices the top end will tapper off a good bit sooner.
The cams I selected for you are good to 5000+rpm.
I have used then all at one point or another.
Thanks Summit 1103 defently considered, seen a video of how it sounds on a chevy 350 sweet, also for $100 for the kit, great Deal!!
