SBC 350 will it be mismatched much? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-10-2010, 06:56 PM
could be a bad exhaust lobe on the camshaft
  #17 (permalink)
Old 06-11-2010, 01:36 AM
Wiki Edits: 31
yea, that's the same 7546 as mine. no provision for the divider and minus the X-Celerator name.. I figured it probably wasn't the best when I bought it. but I really just need somthing to bolt the carb to so I can test fire the engine.. if it runs good enough to use for a while on the street, that's even better but not necessary..
as far as a flat exhaust lobe. it's possible, but the valves were opening and closing when it was run with no valve covers. could be going flat.. it's going to get a new cam anyway, most likely. somthing that is still good for 8.5:1 but with a little chop to the idle. most likely somthing that runs from 1,500 RPM instead of idle
  #18 (permalink)
Old 06-11-2010, 08:15 AM
Greg T's Avatar
www.krusinklassics.net
Did ya check for spark?
  #19 (permalink)
Old 06-11-2010, 09:00 AM
Wiki Edits: 31
with an inductive timing light, but not at the plug. swapped the plugs after the comp test tho, and it was still dead.. but all diagnostics were done 3 years ago.. we pulled the engine, oiled the cylinders and set it in the corner
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
350 sbc pistons Thumpr Engine 5 09-08-2009 06:02 PM
are sbc 350 gaskets sets the same despite the year and/or if its a vortec??? Rod stalker Engine 4 08-17-2009 06:44 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 08:20 PM
