sbc 350 wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2007, 09:17 PM
sbc 350 wont start
the motor was running fine and i put some heddman hedders on it, it was back firing real bad. well i posted a thread about it last night. anyways i checked the firing order to see if icrossed a wire. it was the 5 and 7 according to firing order but then i couldnt get it to start so i went and got some new wires because the ones i had were old. well after new wires and plugs acdelco of course....but i cant get it to start im wondering what ive done wrong. i started with 1 @ about 6:30then 8 ,@ 7:30 is that right?
Old 09-06-2007, 10:03 PM
383silverado's Avatar
the firing order is 18436572.
http://boxwrench.net/specs/chevy_sb.htm
edit- did you accidentally disconnect the hot 12volt wire to the distributor ?
Old 09-08-2007, 01:45 PM
i finally got it i had the #1 plug in the wrong plug ont the cap
Old 09-08-2007, 02:07 PM
305 head on a 350 sbc Trav Engine 41 04-13-2013 08:30 AM
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 03:26 PM
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 09:48 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
350 that doesn't like to start. stocker Engine 10 03-28-2003 04:02 PM
