Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc 355 Build-head Choice.
Old 11-17-2011, 10:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by VARS_85MONTE
Im finishing up a 357 build. This is every other daily driver. I want good torque and HP. I have a set of World Product Sportsman II heads(200cccc) or a set of Patriot Vortec heads(185cc). Here is the rest of the combo. I know you guys will lead me in the best direction
as you did with previous builds.
010 block 4 bolt main .40 bore
Balanced rotating assembly
Forged flat tops (9.72 compression)
LUNATI voodoo 268 227/233@50
Air Gap Intake
Holley 650 double Pumper
1.6 Comp roller rockers
MALLORY ignition
Hooker Comp Shorty headers 1 5/8
Turbo 350 2200 stall
10 bolt 3.73
Like I said before, this is a car I will drive pretty often. I have my "hot rods", I just want a strong toy to drive around.
Any help suggestions and advice is accepted. Thanks in advance guys.
Patriot Vortec's all the way. Below shows a standard SBC intake gasket against the Patriot Vortec head flange. Note the much taller
Vortec port- this means you will need sa Vortec intake to match
them.
Patriot on Left, Sportsman 2 on Right
