Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 355 Cam selection
  #21 (permalink)
Old 03-07-2013, 10:49 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
Ive seen that video several times,thanks
Originally Posted by logan1 View Post
Vinnie I was researching your comment about the single plain intake and how it would be better for my application and i cam across this video that pretty much proves that the air gap is the one to go with. Thought you might be interested in seeing it aswell.
Edelbrock Intake Manifold Dyno Test :: Single Vs Dual + Air-Gap Vs Regular - YouTube
do the math or comparison on higher revving engines. Ive given away performers.
My Z-28 Camaro picked up 4/10s from just changing the performer to a victor Jr
Its true the performer responds at lower RPMs
With a mild engine,hydraulic flat tappet cam, Vacuum secondary middle of the road carb,heavy car,mismatched over size heads,and various other common mistakes,the performer will bridge the gap better.
when you step up,you will see
use the dual plane,some people are very very happy with that type of power delivery and I recommend the dual plane most of the time
I saw an opportunity in your car to show an example of what power is to be had,yours would be worth the improvement.
If you ever come to BC,call me,I will show you what a sports car can do
