2jz is a great engine,but a small block V-8 is no slouch and if its turbo ed then 800 HP is standard
I will some day convert to F.I. also. But it cost me $600.บบ for a custom built 950 so I will suffer with that for now |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
logan1 (03-07-2013) | ||
If you can soulder, Megasquirt PCB3 ECU Fuel Injection Injector EFI Kits | eBay
Get a harness to go with it, a junkyard throttle body, temp sensor, air temp tensor, and o2 sensor plug (new o2 sensor) and you have a very good EFI system that is quite capable- down the road upgrade your intake to a multiport EFI system for even better results. BTW these can also easily control spark timing with a stock chevy distributor from a TBI or newer vehicle. Your total will be around $400 if you don't mind going to a junk yard. Here's a preassembled unit, though its not as nice, its a MS1 v2.2, still more than adequate but not as many bells and whistles as the PCB 3.0, megasquirt v2.2 I'd offer him $150 shipped. Here's a preassembled MS2 unit, which is also a little better than both of th eprevious but a little more costly- Megasquirt II 2 PCB3 Standalone Engine Management ECU | eBay BTW, these units are both upgradable to control COP ignition and sequential EFI if you really feel you need every last bell and whistle. All of them do nitrous control, dual fuel tables, boost control, fan control, etc in even their most basic form. In the end it really makes you question buying a $650 carb... |
| The Following User Says Thank You to ap72 For This Useful Post: | ||
Ive seen that video several times,thanks
My Z-28 Camaro picked up 4/10s from just changing the performer to a victor Jr Its true the performer responds at lower RPMs With a mild engine,hydraulic flat tappet cam, Vacuum secondary middle of the road carb,heavy car,mismatched over size heads,and various other common mistakes,the performer will bridge the gap better. when you step up,you will see use the dual plane,some people are very very happy with that type of power delivery and I recommend the dual plane most of the time I saw an opportunity in your car to show an example of what power is to be had,yours would be worth the improvement. If you ever come to BC,call me,I will show you what a sports car can do |
holley Vs Demon?
You can buy a custom H P holley for a very reasonable price |
Keep the RPM air gap. Upgrade the 700carb with a holley/proform 750HP carb body kit.
Get rear jet extensions and holley float bowl whistle baffles for road racing. Get a Crane F278-2 cam with 1.6 rockers or a Crane F280-2 cam with 1.5's or 1.6 rockers. Both either are fine with power brakes. Nice powerfull street strip/road racer mechanical flat tappet cams. But tame enough for street driving. Crane Cams | Automotive Home Page |
Logan,
Are you in Ohio??. There is a user name of Logan on one of the Astro forums. He owns Mr Bee appliance service. Too bad you couldn't swing a full solid roller and kit from Howards.I've bought a number of cams from them and they certainly build nice stuff.Never had a problem with them. I can I.D. with your project.Yrs ago we built a 1952 MG TD with a SBC,IRS,rocker crusher close ratio 4 speed,it was a 327 with Man-A-Fre induction,Isky solid lifter cam,12.5 SCR,Mondello heads.A riot to drive.Would go around corners like it was on rails.Yep-your project brought back some memories,
How much gain will i see using the 1.6 rockers?
I've always been a big MG fan but being that in 6'5" tall MG's are not cars i fit into. The reason i bought the datsun us because it was the only affordable 2 door sports car that i could fit into. I bet that MG was a blast to drive hopefully mine will be fun once its done. |
Ok from what i have read the 1.6 rockers will only give me 10hp more than the same cam with 1.5's. I also read a few posts that said that they wreak havoc on the valve train; not sure if this is substantiated info or not but at this point im not too inclined to run em.
Also i saw that thread posted by landshark and the problems he is having with 1.65. |
peace Hog |
10 HP is 10 HP. Not a bad gain for just a rocker ratio increase. 1.60 rockers do not tear up the valve train. Landshark is having problems for other reasons. Like the funky pushrods he is using. Not hard to see why the guide plates are getting all carved up, by using those fubar pushrods. People have valvetrain problems for various reasons usually incomparable parts or lift interference or improper geometry (pushrod length) 1.6 rockers on a SBC are not a problem, when installed right. That Crane cam has modest valve lift especially on the intake side. 1.6:1 rockers is a good way to effectively get more net valve lift. increases the rated valve lift (w/1.5 rocker) by a factor of 1.0666. EG: .480" x 1.0666 ='s .512" net valve lift When ever using aftermarket heads you need to pay attention to valvetrain geometry. |
| Cam for SBC 355 | Driver_WT | Engine | 23 | 10-17-2012 07:56 AM |
| sbc cam selection ???? | delawarebill | Engine | 27 | 04-28-2012 08:59 PM |
| SBC cam selection | 2005vette | Engine | 1 | 04-19-2011 02:06 PM |
| Cam selection sbc | david ahluwalia | Engine | 13 | 02-03-2009 01:27 PM |
| SBC cam selection | bonuts | Engine | 3 | 06-09-2004 12:34 AM |
