http://grannys.tripod.com/hillbillyclutchslipper.html |
I quick question before i order my cam today. Have you guys used Assault Cams? I found a really good deal on them and was wondering if its too good to be true?
Sbc Solid Tappet Chevy 350 383 Camshaft Kit 279/282 Gm - KMJ Performance |
This will surely make your car slower and increase the heat in the clutch and kill it faster. Best to just drop it. I move my foot sideways off the clutch not up. A slipping clutch can be killed in a day one that is dead locked will last its service life. Drive line shock is best delt with in other ways. |
Summit cams look cheap and use older grinds but really nothing wrong with them. But they are also not the best grind for long life. USally what you are paying for is not quality manufacturing but good design. Go with a good design price is mute once its whiped and the entire engine needs to come apart to clean and replace. Here is a link about cams. FYI the companies mentioned are owned by the same people. Who made your camshaft Last edited by hcompton; 03-19-2013 at 09:39 AM. |
Sorry to bring this thread back from the dead but i figured it would be better than starting a new one. My greed / eternal quest for more power is kicking in and Im now thinking running the 1.6 rockers is a good idea as suggested by F-BIRD.
I have already ordered the cam from summit: Mechanical Flat Tappet 275/281,.505/.520 Howards Cams Mechanical Flat Tappet Camshaft and Lifter Kits CL110102-06 - SummitRacing.com So I will have the following lifts: Intake (.505" x 1.0666) - .022 = .517 Exhaust (.520" x 1.0666) - .022 = .533 How much power gain can i expect with this change? Also below is a picture of my short block ready to go back together. The cam i ordered is on backorder and will probably get here in the 2 week of april.
You will most likely find the most gain by just using the 1.6's on the intakes only.
The exhaust side responds more to duration changes than lift changes. The changes will be small at best. You can play with the lash too. start at a cold setting .004" less than the hot lash spec. If/when trying a bigger lash setting do not get carried away. You need to change your reference from a how much power for this and that bla bla bla to a reference of actual tested +/- improved performance by trying different stuff like lash and rockers. That cam is small as cams go and will probabily respond well to running less / tighter lash than spec valve lash if you want horsepower. less lash results in increased running valve duration. (makes the cam act slightly "bigger") Last edited by F-BIRD'88; 03-26-2013 at 09:54 AM. |
I get guys who do this and then want the $6000 trans under warranty. You slip the clutch. The disc is cheap, and easily replaced. |
most racing clutches won't "slip" they're not designed the same as a street clutch and go from nothing nothing nothing... bam, locked! That of course is for really high hp drag clutches.
but there is still the split duration.
| Cam for SBC 355 | Driver_WT | Engine | 23 | 10-17-2012 07:56 AM |
| sbc cam selection ???? | delawarebill | Engine | 27 | 04-28-2012 08:59 PM |
| SBC cam selection | 2005vette | Engine | 1 | 04-19-2011 02:06 PM |
| Cam selection sbc | david ahluwalia | Engine | 13 | 02-03-2009 01:27 PM |
| SBC cam selection | bonuts | Engine | 3 | 06-09-2004 12:34 AM |
