SBC 355 Cam selection - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 04-05-2013, 08:28 AM
Originally Posted by vinniekq2 View Post
if you dont know the flow numbers red
227/155
68.3%
with a less than 70% exhaust flow ratio you still wont ude a dual pattern cam?
227 on a 185 cc head? That's pretty bad, now I think no cam will help that
If you go to headbytes.com he had a cylinder head shoot out using pro comps, patriots and brodix. I found it interesting but those heads he has came in last.
  #62 (permalink)
Old 04-05-2013, 08:51 AM
How fast is fast enough?
Patriot 23 Deg 185 Out of Box CHW SF600 Alum 185/- 2.02/1.60 N/A
0.1 0.2 0.3 0.4 0.5 0.6 0.7
56/53 101/83 147/114 190/137 227/155 245/171 248/177
This didn't copy and paste too cleanly but its flow numbers for the patriot 185's. Depending on application a single pattern cam would not be out of the question.
  #63 (permalink)
Old 04-10-2013, 07:53 AM
Any recommendations for spark plugs? My head card casy i need a plug with 3/4" reach. Was thinking about buying a set of Champion RC12YC.
http://www.summitracing.com/parts/cpn-711
If you do not want to register, fill this field only and the name will be used as user name for your post.
Cam for SBC 355 Driver_WT Engine 23 10-17-2012 07:56 AM
sbc cam selection ???? delawarebill Engine 27 04-28-2012 08:59 PM
SBC cam selection 2005vette Engine 1 04-19-2011 02:06 PM
Cam selection sbc david ahluwalia Engine 13 02-03-2009 01:27 PM
SBC cam selection bonuts Engine 3 06-09-2004 12:34 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
