sbc 355 ported vs manifold vacuum for advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 12:05 PM
Hi guys, I have a sbc that i just converted from ported to manifold vacuum on the vacuum advance. Just trying to see if the truck runs better but so far not seeing much of a difference. In fact it may run worse now. What do you guys think about the two?
Old 10-05-2012, 12:24 PM
malc's Avatar
Living At The Speed Of Life
You posted this question on 08-16-2012, 04:34 PM
and got five answers.
Old 10-05-2012, 12:33 PM
I didnt get the answer i was looking for
Old 10-05-2012, 12:41 PM
malc's Avatar
So there is a predetermined answer ?
You must know it then.
Old 10-05-2012, 12:43 PM
nah I don't but no reason to get cocky
Old 10-06-2012, 01:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This has been covered in quite a bit of detail. The problem is, there's no one correct answer for all applications.
You can find more info on this here, as well as doing a search on this (and other) forums.
Old 10-06-2012, 04:57 AM
frank sieber's Avatar
Have tried it both ways on my 358 sbc, 10:1, pumpgas. total mechanical is 34 deg. Direct vac woke mine up on the street, but I had to limit the amount of total advance the vacuum can added at part throttle, mine likes bout 10 deg extra . you don't wanna hear constant pinging at cruise. when the motor is being throttled (cruised) on the street the mixture is leaner takes longer to burn. when you hammer it WFO the vacuum drops out of the picture & your runnin on mechanical total again. Helped my throttle response & plug life. Set timing like normal no vac hooked up, then apply direct vac & it should advance quite high no problem no load idle down just abit if you must. with your lite still on the balancer wick thottle quickly the timing should retard for a spilt second,then advance. This will tell you it's working. Just limit the amount of advance the vac can provides if it pings at cruise. I know every time I use timed vac (above the throttle plates on carb) it was ping city. runnin just mechanical on the street fouls plugs pretty quick. By running full vac it's only "in" at part throttle or idle (high vac ) mash it plates open vac drops off & you're on mechanical again. Remember vac & mech advance are totally different & separate. Any way hope I haven't confused you. I know this setup has helped my street car a bunch. Oh yeah make sure the vac diaphram is not leaking! Just a thought, have a good one.
The Following User Says Thank You to frank sieber For This Useful Post:
stea (06-26-2013)
Old 10-06-2012, 06:50 AM
Answer these questions first.
what is the initial timing?
how much total timing?
and how much added from the vacuum advance?
then read this.
http://www.corvette-restoration.com/.../Timing101.pdf
Old 10-06-2012, 01:57 PM
Yeah, what he said ! My ol' nova likes 12-14 deg. initial, 20 deg. in dist. & 8 deg. with the vac advance. Made it nicer to drive around. now about the points on a guys license !!
Vacuum advance source-ported vs non ported JUSTINH Engine 49 09-19-2013 08:52 AM
Ported vs. Manifold vacuum ttjsk812@aim.com Engine 6 08-17-2012 09:17 PM
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 13 10-07-2011 10:38 PM
Ported -vs- Manifold - Vacuum Advance Scenario Cousin_Joe Engine 25 01-29-2009 06:05 PM
Ported Vacuum or Manifold Vacuum? Regal Beagle Engine 13 09-05-2008 01:30 PM
