SBC 355 Timing Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2009, 10:39 PM
I have finally installed the 355 sbc in my 74 Nova. It's a mild rebuild 9:1 compression, 882 heads, comp cam dual pattern 427/ 454 lift, edelbrock performer intake w/ edelbrock 600 cfm carb. HEI, jegs ceramic coated headers with 2.5" dual exhaust. What would be a good point to start at with base timing? Where should I start with total timing? It will be a street cruiser, just want the most go without effecting reliability. Thanks, Richard
Old 10-14-2009, 10:43 PM
DoubleVision's Avatar
Base timing: 12 degrees before top dead center with vac advance disconnected and plugged. Lock distributor, reconnect vac advance to a manifold source (any source that pulls vacuum full time, even at idle) recheck timing, it should be 20-24 degrees. 36 degrees total past 3000 RPM is the common.
Unusual SBC timing problem 85GMCguy Engine 13 08-06-2010 06:48 AM
sbc timing with no timing tag excaliberprime Engine 5 04-14-2007 10:58 PM
Timing mark question Kevin45 Engine 4 07-12-2005 07:46 PM
sbc balancer question STATUTORY GRAPE Engine 8 07-11-2005 06:59 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
