Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 358 Build for Economy
Old 10-12-2009, 08:00 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
The only reason i am considering the 882 heads is because the intake bolt pattern is designed for earlier heads. I have a set kicking around, and i have flat top pistons which would yield about 9.0:1 compression. Maybe some small chamber 305 heads with 1.94x1.5 valves will work better but then i will have to get different pistons. 70mph should be about 2200 rpm is that a good cruise rpm.
