SBC 360 Build
Im building a sbc 350 bored .060 over to put in my 57 chevy truck (5500lbs). Im using a Magnum Flat tappet comp cam (.499 lift, 270 duration), Sealed Power hypertonic flat top pistons, stock chevy heads with 1.74 in, 1.50 ex valves with comp cam recommended valve train components, performer eps intake, Holley 650cfm electric choke vacuum secondary carb, and its in a 010 4 bolt main block. And behind it is gonna be a 2000 stall 2 speed powerglide. What I'm wanting to know is if these parts will go good together and is there any changes yall would recommend I change keeping in mind this will be kind of a budget build? Oh yea I intend on using as weekend driver street truck and where I live emissions are not a concern as far as being checked.
