Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 377 Build ?
Thread: SBC 377 Build ?
  #16 (permalink)
Old 08-23-2010, 09:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Charliedclayton
i dont think this crank shaft is oem at all. everything but the heads/intake/cam looks new and hasnt got real if any wear on it at all. iv looked up the crank numbers and havent found anything at all, but in full rotation the pistons travel 3.75 inches total from top of stroke to the bottom
Then I guess I don't know. Usually, $150 engines from old bread trucks aren't 377's, but I suppose stranger things have been built.
BTW, what's the rod journal diameter? You could have an offset ground LJ crank fitted w/SJ rods, can get a 3.5625" or 3.625" stroke that way. We used to call these engines "9/16" and "5/8" engines, respectively.
More displacement can be had from a LJ crank if it's based on the 1.88" Honda rod journal size.
All I see on the piston p/n shows a rebuilder-type (1.540" pin height) 350 piston.
Good luck.
