SBC 383 Oil Pan Problem??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 01:38 PM
89SDime's Avatar
I have an 84 chevy 350 block that has a 2 piece seal. I got an Eagle 383 Storker kit for this block but heres my problem. It goin in an S10 pickup and they make speacial pans for this. Heres the pans they make
Pre 79 blocks 2 piece seal Driver side dipstick
87-up 1 piece seal passeners side dip stick
They dont make a pan for 80-86 so neways i started looking for regular pans but i cant find a pan that will have stroker clearence (3.75 with Eagle rods) and fits a 84 block. Every stroker pan is pre 79????
What can i do??
Old 09-26-2006, 11:39 AM
What can i do??
Are you sure you need a stroker pan? The 3.75 stroke came in a 400 block and its the same size as a 350 other than bore and being siamesed. He!! I've put regular pans on a 383 in a monte carlo before.
Old 09-26-2006, 01:48 PM
Even the small front sump Nova pan will clear a 3.75" stroke crank.
I cannot get my oil pan gasket to seal undy Engine 2 05-12-2006 05:21 PM
Sbc Oil Pan sexypizzaman Engine 10 05-10-2006 10:35 PM
Possible oil windage problem? Mad Maggot Engine 5 07-28-2005 10:31 AM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 01:32 PM
7qt Oil Pan & Pickup SBC Small Block Chevy Mustangsaly Engine 6 06-12-2005 07:52 PM
