Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
Old 10-03-2012, 10:54 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
The power figures you are asking for are very close to what my engine makes,this is the basic list of parts Im using,just for comparison,nothing else. I hope it helps:
10;75:1 434 cube,dart block/heads
heads are 227 cc and came cnc ported,then they were cleaned up a little,my camshaft is solid roller 256/264 duration with 108 degrees icl and 108 degrees of lobe separation,installed straight up
.420 lift X 1.5 and 1.6 shaft mounted rockers. victor junior intake with a modified 950 HP. headers are jere. 1 7/8 step headers. my engine makes peak power at 6470 rpm ( on the dyno) revs to 7k with out much power drop but torque goes down
