Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
Old 10-04-2012, 05:27 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by desmosis10 View Post
Do u think I should just stay with the cam that i have already/ Cause i want AT THE LEAST CLOSE TO 550HP any thing over that would be a BIG PLUS..
The HYD Roller cam I have with this set up now is a Lunati Voodoo cam....
THIS IS THE HYD ROLLER CAM I HAVE FOR MY 383 STROKER
How much Hp could I have with just keeping this cam???????????
•Advertised Duration (Int/Exh): 282/290
•Duration @ .050 (Int/Exh): 231/239
•Gross Valve Lift (Int/Exh): .535/.550
RPM Range 2500-6500
108 Lobe sep
You don't need that big of split with those heads, using a hyd roller with only .535 lift I don't think you will meet your goal.
