Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
Old 10-04-2012, 11:44 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
split duration camshafts "usually" have more duration on the exhaust side.afr have a very good exhaust side for breathing sometimes as high as 80% of the intake side.Cam grinders quite often include 6 or more degrees duration on the exhaust side to make up for standard OEM heads and other heads that have less flow on the exhaust than what is desired.
Instead of looking to squeeze more power out of a 383 why not squeeze more cubic inches into your caR
