Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
Old 10-04-2012, 08:01 PM
ap72 ap72 is offline
Banned
Originally Posted by desmosis10 View Post
Question?????....I'm getting built a SBC 383 stroker I trying to get between 550HP to 600HP or better to the flywheel, I want to kno if used a custom camshaft. For example a 565/585 lift @.050 duration 244/252 and wanted my RPM range between 2500-6800 or 3000-7000 RPM is it possible to get it with a cam like this with my SET UP below... I am just respectfully asking for some input if you would? Thks Des
I'm new to this, I have been always into muscle car & performance engines. Im getting built a 383 Stroker going with TRW forged pistons .30 over, Forged Scat I Beam rods , 4130 Eagle Crank,World Products Motown Intake Manifolds Part#061040 rpm range 2500-7500 , Airflow Research (AFR) 1103 - AFR 210cc SBC Eliminator Competition Heads. I swapped the solid roller 710lift springs for the 650lift hyd roller springs cause of a hyd roller cam I want to go with...
[B]Compression between 10:5:1 to 10:8:1[/B
The HYD Roller cam I have with this set up now is a Lunati Voodoo cam.... How much Hp could I have with just keeping this cam
•Advertised Duration (Int/Exh): 282/290
•Duration @ .050 (Int/Exh): 231/239
•Gross Valve Lift (Int/Exh): .535/.550
RPM Range 2500-6500
108 Lobe sep
can you change your pistons? maybe your rods? There's easy power right there.
