Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
  #17 (permalink)
Old 10-05-2012, 12:28 AM
desmosis10 desmosis10 is offline
College kid into Muscle cars
Originally Posted by cdminter59 View Post
Sounds like a good performance motor. Are you using 5.7" or 6" rods? You probably were on the right track to make 550 hp with the mechanical roller. Now with the hyd. roller you chose I would say it might make 500-530 hp with a 850 hp carburetor. You could do some mild porting to your heads and intake, that might help you to get the 550 hp. Not bad for being new!
Thanks I appreciate the info, and I using 5.7 rods scat I beam rods, but I have a question if i was to go with a bigger cam Lift & duration, Could I make more HP & TQ, I just wanted to do HYD Roller for my first engine build, and try to get close to 550hp or better....
For example>>>>>>
565/585 lift duration @.050 244/252
575/590 lift duration @.050 248/254
585/585 lift duration @.050 248/248
