Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 383 stroker opinions & cam Questions???
  #22 (permalink)
Old 10-06-2012, 06:44 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by desmosis10 View Post
I'm using a 1974 4 bolt main block.... My block have been hot tanked, bore and hone, deck clean, and on its way to get a line bore for steel billet main caps that's all I no so far is there anything else to do to gain power????
I understand a solid roller cam will get me more hp and torque, But HYD Roller is that way i'm going. I alread paid for everything I can't really turn back now. Maybe I just need a bigger cam with good duration,What do u think??????
On those AFR heads its a good idea to check the chamber for CC volume as the last set was suppose to be 65 CC and when chacked they were 67.5 CC
On the OEM blocks its a good idea to sonic test for cylinder wall thickness.
Also why are the putting the caps on last as every thing measures of the main.
If your looking at 600 horse it would be a good idea to go to a splayed cap.
If your looking for good ring seal have it plate honed.
