SBC 388 S/C Weiand 177 Help in Tuning - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-20-2012, 11:43 AM
Ok, i will measure all the stuff i have here, thanks for your help
  #17 (permalink)
Old 04-20-2012, 11:50 AM
F-BIRD'88's Avatar
Yada Yada Yada
Originally Posted by TJ555
spark advance is only mechanical, not vacuum advance, i got all advance at 2500-2800rpm like 32, al sensor are above supercharger
this will not work. The sensor on the TBI body sees a vacuum when the blower is @ WOT pulling hard on the TBI.
The MAP sensor sees this as part throttle cruise engine operation, when the engine is actually WOT full power under boost.
It trims the fuel curve instead of increasing it.
It advances the timing instead of retarding it under boost.
( if it controls spark advance in any way.)
This EFI system is not roots blower motor friendly.
If it was, the MAP sensor would be on the intake manifold under the blower.
its not going to work right on a blower if its for a N/A engine.
The map sensor must be boost referenced just like a boost referenced power valve when using a carb on a blower motor.
Or a second "bypass" "boost" sensor on the manifold or a WOT throttle switch to by pass the false vacuum signal it is seeing at WOT.
If you do not want to register, fill this field only and the name will be used as user name for your post.
weiand 177. anyone take one apart? homerj55 Engine 23 07-23-2011 03:07 PM
weiand 177 and water meth on sbc homerj55 Engine 19 06-08-2011 11:18 AM
weiand 177 vs 250 Roald Engine 11 06-02-2009 12:59 PM
355 SBC weiand 177 question rising68 Engine 7 08-14-2008 06:54 PM
400 SBC w/ 177 weiand..expected hp? Dr. Jeckel Engine 28 03-07-2007 07:00 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
