GM was known to reuse engine suffix codes, that is where the date codes come into play. You are correct the crank will eliminate any doubt. |
Problem solved. Now does anyone need a 1969 350? I dont want it. |
SBC #3970010 is this a good block
If it is actually a 69 model and it appears to be that then here is the GM info for that HV designation: HV 1969 350 255 4 turbohydro 350 This would then go along with your saying it has dish pistons and big chamber heads.
A 69 Date stamped engine, not casting date, would not be installed in a 1970 car. The engines are stamped at final assembly, part of the stamping is the installed vehicles partial VIN, also in 1970 GM went to a three letter suffix code from the previous two letter.
One other thing, the Janesville final assembly built full size Chevys in 69, not Chevelles. |
"V"= Flint plant, "0329" is March 29th, "CKM" is 1976 350 cube "LM-1" 170hp 4 barrel w/Auto transmission, installed in either F, A, B, or X body car(F=Camaro, A=Chevelle/Malibu, B=Caprice/Impala, X=Nova). Code info was from www.nastyZ28.com The "7" in 17K524345 indicates 1977 car and goes along with the info from chevyMania. ChevyMania also shows it to be 170hp. Last edited by ericnova72; 12-02-2010 at 07:00 PM. Reason: more info |
Help with this 350 block
Ok guys I need some help I have a 350 block and I have been unsuccessful in tracking done the year it was made. On the front pad by the right head I have the stamped number 87789 and under that is the letter c but that's it no letters no vin or anything. So I am not sure how to decode it any help would be great. Also I read on this post abut the 4 dig code on the opposite side of the cast number 3970010 that you might be able to us it to tell the year the code is c175 It Has the 010 020 numbers next to the filter but followed by the number 158 and at the rear of the block next to a freeze plug it has h7 and under that 509 and last next to the casting number it has a large gm 18. With all this info can anyone tell me about this block. I feel I have did my home work on this but is there something I am missing
3970010 motor
This was the replacement block (should be a 350) when you blew up a mostly late 1968 and very few Jan. early 1969 Z28- 302 car. This was the dealer replacement block if your car was still under warranty. My friend has the complete motor. He blew his up and the dealer put this motor in it. He took it out complete and still has it wrapped in plastic. He put a big block in the Z28 and raced it and sold the car, the guy did not want to buy the small block when he sold it.The heads were correct(same that came with car) but had a chevy bow ty on the manifold. (1968)I could not understand that. I would like to buy it just to keep and sell later for profit if I was sure it has the correct crank and pink rods, thats what makes the 302 out of a 350 block. I hope that helps, the old original GM parts books have that number in them just like the guys already said.
