Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC 400 -- 5.7 or 6" rods..???
Old 08-15-2010, 09:17 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
About all the longer rod does is allow the piston to be lighter, as it is shorter. There is a very small advantage to the longer rod in higher rpm enviroments and with restricted head flow #'s as they will very slightly help cylinder filling, but those criteria are beyond the scope of what you are wanting to do RPM-wise. At the level you want to go, there is no real difference between the two, use whichever you want to.
