Sbc 400 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-16-2013, 06:09 AM
Originally Posted by F-BIRD'88 View Post
A cylinder head swap really wakes this motor up.
The stock 997 heads are pretty lame. (265HP)
pretty much any high performacne cylinder head you bolt on this is a
big improvement.
Stock pistons. Dished, flat top?
what is it going in? what rear gear ratio?
is there enough in the budget for new aluminum high perf heads?
Has stock pistons for now but looking to go with flat top and 5.7" rod and it's goin in a 1987 gmc short wide stock gears in rear end
  #32 (permalink)
Old 09-16-2013, 09:49 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Two things with a piston swap.Check the all bores with a dial bore gauge especially the thrust side.If needing a bore to straighten out the bores back to round,do no machine work unless the intended pistons to be used is in the hands of the machine shop to properly size the bores and sonic check the bores on a relative thin walled engines and only finish bore only with torque plates.
Secondly watch your SCR/DCR's with head swaps and flat tops/5.7's.Diffidently buying good quality aluminum aftermarket heads is a step in the right direction.These engines like intake runners in the range of 195CC or for low end 180cc's.
  #33 (permalink)
Old 09-17-2013, 08:30 AM
big improvement.
Is that 265hp sae net or gross?
peace
Hog
  #34 (permalink)
Old 09-17-2013, 09:28 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Sae net horsepower was introduced in 1972. 400sbc started 1970. They started as 265 HP. I assume gross. Knock off 20% and that is the real horsepower to the rear wheels.
400 sbc. . T-400 or 700r4 blackpanther68 Transmission - Rearend 2 08-05-2012 05:32 AM
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 06:17 PM
400 sbc Devin 427 Engine 19 06-08-2010 07:17 PM
400 sbc help preditorbro Engine 9 01-18-2010 06:04 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
