sbc 400 build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2002, 06:45 PM
Angry sbc 400 build up
need some ideas on how to get good cheap power out of my 1978 chevrolet small block 400 <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 12-18-2002, 07:13 PM
BOBCRMAN@aol.com's Avatar
Post
Intake, carb, cam, headers, ignition, all basic small block stuff.
Old 12-19-2002, 08:21 AM
Post
what is it going in? i would get a cam intake like ^ said but also a set of 64cc heads to raise the compression up. if you you are not building the bottom end. where did you find a 400 sbc i have been looking for since ive been into cars and soo on i know they have a problem with over heating but i would love to have one do you have any more just lying around
Old 12-19-2002, 08:43 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by 85 regal:
<strong>where did you find a 400 sbc i have been looking for since ive been into cars and soo on i know they have a problem with over heating but i would love to have one do you have any more just lying around</strong><hr></blockquote>
I hear this all the time, but mine and others I know with 400's dont have any problem with overheating.
Chris
Old 12-19-2002, 10:22 AM
banned
Post
The only way 400s have problems with overheating is if you don't run a good rad or water pump or if you use the wrong gaskets for the heads... (YES people even the 882 heads are okay if you use the proper gasket)
Old 12-19-2002, 04:08 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
I agree with TurboS10 I never had a heating problem with any 400 block. Hot on mine is when crusing Woodward and sitting still for long periods and heats way up to 195*
Luv the smell of NITRO in the morning.
Old 12-19-2002, 07:02 PM
Post
I just finished a 400 4-bolt for my 68 camaro, the only overheating problems I've seen were from a passenger when I stood on it, or other builders who use non-400 heads and forget to drill the lower steam holes !!!
Old 12-19-2002, 09:41 PM
Post
maybe the reason i have seen the over heating problem is cause the only people ive seen with these are pushing over 500 ponies and have the block filled with concrete to the waterpump holes. thats probly the reason ive seen them over heat sorry if i offended anyone
Old 12-20-2002, 05:27 AM
TurboS10's Avatar
Wiki Edits: 2
Post
<strong>maybe the reason i have seen the over heating problem is cause the only people ive seen with these are pushing over 500 ponies and have the block filled with concrete to the waterpump holes. thats probly the reason ive seen them over heat sorry if i offended anyone </strong><hr></blockquote>
No offense at all. The grouted block should not have problems with water temp, but oil temp. With the cylinder walls full of grout there is no place for the oil to loose its heat. An oil cooler is needed in that setup.
Chris
Old 12-21-2002, 03:36 PM
1BAD80's Avatar
Wiki Edits: 2
Post
agree with TurboS10, and no offence taken. Its just like a few others stated, its the way the motor is put together, along with the steam holes.
Old 12-21-2002, 06:05 PM
New Member
Post
For anyone looking at putting non 400 heads on a 400 block, the Super Chevy magazine that just came out has an article on how to drill steam holes in the non 400 heads.
Old 12-21-2002, 07:25 PM
Post
Any reputable machine shop should be able to drill the holes for a nominal fee. If I recall, some of the holes have to be drilled at an angle not perpedicular to the head deck. It's not really something I want to be doing in my garage with a hand held drill.
