sbc 400 crank measurements - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2012, 03:46 PM
If a 400 crank on mains is turned. 020 over what shout it measure at and if the rods are. 010 what they measure at?
Old 12-03-2012, 04:26 PM
BOBCRMAN@aol.com's Avatar
UNDER size. You can't oversize by grinding. 2.650" is roughly the stock spec. So .020 under would be 2.630". Rods would be 2.100" minus .010". =2.090"
Old 12-03-2012, 04:31 PM
Mine measures 2.633 so it would be .020 and rods are 1.973
Old 12-03-2012, 04:58 PM
The rod dimension you give is for a .030" under SMALL journal (2.00") 1955-1967. Re measure. You are .003 " too big in both your measurements.
Old 12-03-2012, 05:09 PM
I used a digital caliper(i know its not a true reading) ill bring it to a shop tomorrow to get it checked. I measure 2.633 main and 2.087 on rods..yhe motor was rebuilt(406) and the main and rod bearings were both .010 and it had a steady small knock at idle.i took it apart and rods were tight on crank and mains were loose so i mesured and figured they put the wrong bearings in and the knock was on the main.
Old 12-04-2012, 08:43 AM
Ok got it micked.mains are 2.63750 and rods are 2.08950
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
SBC 400 crank thoughts. DoubleVision Engine 11 03-03-2010 02:11 PM
sbc 400 will not crank sscanrun Engine 10 09-28-2009 07:12 PM
SBC 400 crank in a 327? anatram Engine 8 02-13-2008 05:38 PM
Cast 400 sbc crank tjk2000us2000 Engine 3 06-29-2002 05:18 AM
