-   -   sbc 400 "first build" (http://www.hotrodders.com/forum/sbc-400-first-build-212980.html)
red400cisbc 01-21-2012 02:42 PM
I have a 2wd 1984 chevy c/10 shorted. I am looking at building a sbc 400 to replace my old worn out 350. I am not concerned about fuel mirage for this will just be a weekend truck, but I do want to keep it running on pump gas. I would like to have some where close to
450 hp. I have a th-350 trans hooked up to a 10 bolt with 342 gears and a locker.
Im thinking of anywhere from 9.5-1 compression to 10-1 compression. Any head and cam suggestions? To reach my goal.
eloc431962 01-21-2012 02:49 PM
How much is the budget for this build and do you already have the 400 block and what parts do have on hand now ?
Cole
:pimp:
cool rockin daddy 01-21-2012 08:08 PM
Go to the junkyard and buy a 5.3 LS truck engine. Pick up running motor for about $400-$500 bucks. Stab a cam in it that has around 212/218 duration split, .530 lift, and a 114 lobe seperation angle ($150). Have the heads fully ported and larger valves put in (cost $1350). Put a different chip in the computer and you're sitting at 430HP and 430 TQ for $2500 approx. You can get a lot more power by going bigger on the cam. Why oh why mess with a Gen 1 engine when you can get LS power and reliability so damn cheap?
Augusto 01-21-2012 09:15 PM
edelbrock Performer RPM heads manifold and cam should give you 400+ hp from your 400 SBC, cheap and easy to build.
red400cisbc 01-21-2012 11:20 PM
Cole
:pimp:
Yes I already have it. Its all stock but has been bored. 30 over.
red400cisbc 01-21-2012 11:23 PM
Y when I already have a 400. And if I went that route why a 5.3 why not just go ahead and go for a 6.0.
cool rockin daddy 01-22-2012 06:15 AM
Well, sport, if you had said you had the engine already you would have saved me a lot of time. Good luck with your build.
