SBC 400 head help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 08:34 PM
SBC 400 head help
Greetings! I am in the process of building a SBC 400 .040 over with a 350 crank and rods, though I think only the bore will matter in this question, it is going in a hobby-stock class oval track car, as such the rules on heads are greatly limited
open chamber heads no less than 72cc 194/150 valves etc., I have a set of 882 casting heads from a 350, they have been cut but I do not know exactly how much, around 70cc is all I know, it should pump legal on the gauge with these heads either way, however.. the machine shop I took them too said they will not work on a 409 block because of the steam holes, he says once you cut the new style heads you cannot put them on a big bore engine because the head gasket will not seal
he pointed out the space between the chamber and water passage is too small for a big bore engine, he claims you need to run old style heads that have the "closed type" water passage with just 2 holes drilled this picture illustrates what I am talking about, just for the sake of understanding.. personally I see no real difference between open or closed with holes in each corner.. still a void there
I have asked around for a few different opinions, and all I can seem to get is "try it and see" which is not what I want to hear, so.. what are the hazards of putting newer style heads from a 350 (882s for example) on a .040 over 400 block
by the way, the machine shop also blocked off the steam holes in the block, if that matters, I thought that sounds like a bad idea but my opinion was not requested, he just did it
Old 06-15-2013, 09:13 PM
BOBCRMAN@aol.com's Avatar
I would find another shop.. 882 heads came from the factory on many 400's. They would have to be cut well over .030 to be borderline thin. You need the steam holes if the engine is operated below 2000 rpm.
drilled 882's will work well for you. As long as they aren't cracked.
Old 06-15-2013, 09:25 PM
The engine will operate between 3100 and 6000 at WOP constantly every Saturday night, 4 blade racing fan with an aluminum racing radiator and a good fan shroud, will the lack of steam holes in the block hurt anything ?
the area they are talking about in the head is this
the areas in red, some are claiming that this "space" shrinks when you cut the heads and if you put them on a 400, the head gasket will not seal if the head has an "open" passage like the vortecs on the right, they say you have to run the older style "closed" passage with the drilled holes
I have no idea really, I just want more opinions, to my eyes there does not seem to be much of a difference between the two styles
Old 06-15-2013, 09:34 PM
"to my eyes there does not seem to be much of a difference between the two styles"
The only time I ever had a problem in that area was way back when angle milling was popular and old camel back heads would get real thin in the area.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
techinspector1 (06-16-2013)
Old 06-15-2013, 10:21 PM
so basically, these heads are perfectly fine for this engine, and someone is blowing a lot of smoke my direction?
probably trying to convince me to buy some heads from him that "will work" though they have not came out and said it, 400s are a new experience for me so I am a bit gullible right now, but thanks for giving me some more insight
Old 06-15-2013, 11:02 PM
vinniekq2's Avatar
what is the maximum displacement allowed in hobby stock? I thought it was 360?
Old 06-16-2013, 01:33 AM
are you angle milling?
Old 06-16-2013, 03:19 PM
To answer your question about the "steam ports"; 85% of the overheating troubles that I've encountered
with SB 400, has been due to the blockage of the steam ports, in some way, shape, form, or fashion.
Either by using wrong gasket, wrong head, dirt dauber nest, or just plain old crud.
I would think that those steam ports were put there for a reason, because coolant cannot flow between the cylinders, and the pocket there, will become a "dead water" space, and will develop hot spots.
When punching out the cylinders you make the walls thinner, allowing them to heat up faster, If anything, I would think in a bored sb400, the steam ports would be even more important.
Old 06-16-2013, 05:29 PM
ericnova72's Avatar
More for Less Racer
In the water passage area you are worried about, BobCRMan's post says it all....find another machinist, yours is blowing smoke up your ***.
This area only becomes a problem on heavily angle milled heads...even if your 400 was bored .060"over(max bored) it still wouldn't be a problem with the heads as pictured.
The Following User Says Thank You to ericnova72 For This Useful Post:
Old 06-16-2013, 05:44 PM
techinspector1's Avatar
Wiki Edits: 326
You can drill the steam holes yourself if you have access to a drill press.
Technical Articles at Greg's Engine & Machine
I would drill the steam holes in any heads that were destined to be bolted onto a 400 block, regardless of the operational rpm's. Be sure to use head gaskets that are drilled also. Either drill and pin or spot weld the impeller to the water pump shaft to prevent it spinning on the shaft and moving no water. Install an anti-cavitation plate on the impeller at the same time. Been there, done that.
Old 06-16-2013, 09:49 PM
So, blocking the steam holes was a bad idea all around, I figured as much but what can you do about it now?
the heads are not going to be cut very much either way, we are only allowed 72cc but we can get away with less, however we cannot get away with running anything other than pump gas, so bumping up compression too much is not going to fly, no angle milling or anything like that just out of curiosity while somewhat on the subject of compression, if you run a compression test on a sbc400, how much would it have to pump before running racing fuel would be necessary? I have been told between 180/190 to run avgas, above 190 run racing fuel, does this sound reasonable?
I have never heard of an anti-cavitation plate, what exactly is it and where can I buy one?
Old 06-17-2013, 12:55 AM
Wiki Edits: 326
Flow Kooler Water Pump Disc - Water Pump Tech - Car Craft
I don't know if they're still commercially available or not, but they are a snap to make from raw material.
Old 06-17-2013, 02:44 AM
vinniekq2's Avatar
av gas is not that great of fuel for ,,,,anything.Too much lead,plugs do foul.I had to clean my plugs every 50 flight hours when I used 100 LL in my Cessna
Old 06-17-2013, 12:37 PM
I've built a 4oo in the past with 327 double hump heads I used the 400 head gaskets as a guide for drilling the necessary holes into those heads it worked on a drag car for several years that was street driven in the south with no issues.. finally went to a cast dart head that went a lot faster with less cam... it's in the flow
Old 06-17-2013, 05:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some info: Drilling steam holes
BTW, I see the Crankshaft Coalition wiki articles now contain links from advertisers.
400 sbc head gaskets. byrddogg65 Engine 1 06-24-2012 05:22 PM
sbc 400 head gasket help kraftada Engine 1 03-06-2012 08:42 PM
SBC 400 cylinder head question JohnyR17 Engine 9 02-28-2007 05:12 PM
400 sbc head rufusdiddy Engine 6 08-01-2006 06:47 PM
400 SBC Head Gaskets MI2600 Engine 2 07-21-2002 02:41 PM
