SBC 400 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2003, 06:39 AM
wcpalmex's Avatar
Question SBC 400 heads
I recently picked up a pair of sbc 400 heads (casting # 3932442) I have read several places that in order to put 350 heads on a 400 you need to drill steam holes in the heads. But I am tring to do the reverse. put 400 heads onto a 350, are there any modifications that need to be done, or will they even fit at all?!?!?!?
Old 06-15-2003, 08:00 AM
V8 S-10's Avatar
v8s10.org
Just use a 350 head gasket and it will work fine.
Old 06-15-2003, 08:56 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Yes drill the heads, and if they are 2.02 int. valve's you need to check the clearance of the piston to valve along with cam lift. The relief pockets may not be large enough. Look in the Knowledge base and some sites tell you how to drill the holes/sizes and the angle. Its not hard if you can use the correct tools.
I use a Fel-pro #1014 Performance Marine head gasket with the steam holes in them. A regular gasket is # 1010.
Use new head bolts, or better yet studs.
Luv the smell of NITRO in the morning.
