Sbc 400 Oil Pan
6K views 7 replies 4 participants last post by  Joshua Lee
i bought a alum oil pan from summit racing a few years back was gonna put a 350 in tbucket but left it go and just go fig now i put it together with a 400 small block problem is summit catalog says there would be a problem in a 400 or a 383 stroker so i called them they said it will fit but i will need to notch where crank weight hits pan :( ive put pan on and off 3 times turned eng over cant see where comes close any one have idea ? thanks i have another post where im having problem with the frame any help :)
#3 ·
The last time I pulled my 383 I thought I would change to a recently refurbished pan. When I got it back together I couldn't figure out why it wouldn't turn over by hand. I then noted that the old pan had some very slight indentations at places along the pan rail.
I would say that if you can turn it over without it hitting on the stand you're probably ok. Don't forget each engine has slight differences due to core shift.
In 1982 I went to all the trouble of cleaning up a stock small block oil pan, knocked out a dents it had, got it all cleaned and painted so I could bolt it to my '73 400 small block.
Got the pan on, fired the engine and instantly learned I now had a nice, loud squeal out of my 400. I could not figure out what the noise was or the cause of it? Then it hit me, it's the oil pan I just put on.
So I drained the oil, pulled the pan and sure enough the crank was hitting the pan in the front.
Maybe this is why summit says their pan isn't for a 400 small block?
While I cranked my 400 over I didn't hear a thing out of it? After it fired I sure did.
