sbc 400 problems - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-01-2013, 09:46 PM
This is what I mean, the old one was the one I pulled off, it has a metal plate in the middle with a hole and the new one has nothing, what do I do?
  #32 (permalink)
Old 07-01-2013, 09:54 PM
That is for the exhaust cross over that heats the intake system for cold weather operation. I believe this is in a boat so I don't imagine you need/want the exhaust to be heating the intake so just let the new gaskets close of that cross over. The only exception would be if you have a mechanical choke that requires the heat in the intake to open the choke.
  #33 (permalink)
Old 07-01-2013, 09:59 PM
No there isn't even a choke on the carb, so I should just run the gasket like that and plug the holes
  #34 (permalink)
Old 07-01-2013, 10:02 PM
That's my 2 cents, other can chime in.
  #35 (permalink)
Old 07-03-2013, 09:30 AM
Anybody with other suggestions? Can I just cut the gasket
  #36 (permalink)
Old 07-05-2013, 04:58 PM
Richiehd's Avatar
JS-70
Is there a hole in the intake manifold? If not, you don't need it it, run gaskets as they are.
  #37 (permalink)
Old 07-05-2013, 05:08 PM
Yeah the heads and the intake have the heat crossover thing
  #38 (permalink)
Old 07-05-2013, 05:14 PM
vinniekq2's Avatar
if you need a cross over,then cut a hole.
Most high performance people block the hole
  #39 (permalink)
Old 07-05-2013, 05:21 PM
techinspector1's Avatar
Wiki Edits: 326
Get a ball peen hammer or other metal tool that has a rounded end on it. Lay the intake manifold on the bench upside down. Lay one of the gaskets on the intake and drop 2 or 3 bolts through the bolt holes to locate the gasket on the manifold. Lightly tap the gasket at the edges of the heat passage hole. Many light little taps will score the gasket perfectly for you to cut the piece out with a sharp knife and make a passage for hot air. Do the other gasket the same way.
400 sbc problems 80camaroguy Engine 12 08-10-2011 09:40 AM
400 sbc running problems sunnyd 95 Engine 9 02-24-2010 07:37 PM
SBC 400 Starter problems weedy64 Electrical 3 05-07-2009 02:03 PM
Is .040 on a 400 sbc just asking for problems? ddhens Engine 30 08-28-2008 11:21 AM
What problems should I look for in a 400 sbc? stonedchihuahua Engine 8 11-05-2002 03:36 PM
