SBC 400 spark plugs. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 06:19 PM
31 five window
Last journal entry: Moving along with patch panels.
I have a 1971 400 SBC in a 4X4 Corvette.It has flat top pistons and a performance cam but I don't know the specs.It has the old camel hump heads so I need the old style spark plugs.It has a stock HEI large cap dizzy. What is the best plug to run for the street and a little off road fun?
Old 06-01-2011, 08:38 AM
OLNOLAN's Avatar
Gasketed Plugs
Speedy, a R44 AC plug should get you in the ballpark. As you know, the early double hump heads use the gasket seat plug. Can't use the tapered seat peanut plugs. Nolan
Old 06-01-2011, 09:01 AM
31 five window
Thanks,yes I did know I needed the big plug thats why I stated camel humps. I did not know if it made a difference that I had HEI instead of points. Now I know what to do. Thanks again. Come visit when you can.
What Spark Plugs? jsarnold Engine 1 02-18-2010 12:12 PM
Spark plugs tornado-tech Engine 9 02-18-2007 08:26 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
Spark plugs + HEI solidaxel Engine 7 11-27-2006 11:35 AM
which spark plugs? FoxThunder 5.0 Engine 8 08-14-2003 12:57 PM
