Wouldn't the valves not open if it was too tight? |
The manuals can be confusing for someone not familiar with them, the "spin the pushrod" method gets more young guys in trouble than you can shake a stick at. You need to spin the pushrod until you just feel a very slight drag, not bound up and no longer able to spin. What you have done is bottomed out the lifter plunger. A better method is to jiggle the pushrod up and down until you feel all loose play is removed, then add 1/4-1/2 turn more to preload the plunger into just some of its travel in the lifter, then lock it down. Go back to your valves, loosen everything off, and set them using the method I just outlined above, the "jiggle method". More than a few of use oldtimers wish they would just quit printing the "spin method" as it fouls up more people than it helps, it seems. works okay for someone familiar with it, or someone who has a teacher familiar with it guiding them, but it hooks a lot of rookies. |
This is my first larger motor with anything like that adjustable. I've only worked on rice burners and small 4 cylinders
I do appreciate the help. I won't be at the garage until hopefully tomorrow and I will pull everything off and try again. I was always told to tighten them until there was no play, up or down or twisty and then tighten the center nut. Hopefully I can have some good news to report back tomorrow. Other than that the thing is ready to go (and it better go soon as it needs to go in storage for the winter) |
And just to clarify, ensure each lifter is on the back side of the lobe when adjusting it, not on the ramp or up on the lobe.
All my toys are in winter storage already, good thing too, we had a "cold front" move through, it dropped to 45 last night, 75 and clear today....sorry, couldn't help saying that, but I just moved here from Alaska last July, already paid my dues for 37 years.... |
Good to know it's a common mistake.
Just to verify this (since I have time to ), at TDC, tighten the nut to where the pushrod is just starting to feel tension. Should have no up/down movement. Then 1/4 to 1/2 turn and then tighten the center allen nut all the way down. That's all!I hate Chicago weather. Near 50s today, was 70 last Monday, was 20s the rest of the week. Car is in the garage being used for storing her, but I don't like starting the cars for the first time in the garage, especially since they like to catch on fire like today. |
I always do the same but I go by the rocker arm. I tighten it down to zero lash on the rocker arm an top of valve. Tightened to where there is no slack an you have side to side movement with rocker arm on top of valve. Tighten additional 1/2 to 3/4 a turn an you are done.
Note, make sure lifters are primed. |
Yep it's a common mistake till you adjust the valves to far/to tight and brake the valve off and lock up the engine. JMO Cole |
Almost sounds like someone dropped the distributor in before rotating the the crank 360* after installing the timing chain. If that happened, the cam would be 180* off from the crank.
Correct alignment would be dot on cam gear and crank gear at 12:00 not 6:00 on the cam and 12:00 on the crank.
[QUOTE=ericnova72]Yep, rattle the pushrod up and down and tighten rocker nut until there is no free clearance left, this is known as "zero lash", then anywhere from 1/8-3/4 turn farther to set the lifter plunger into its hydraulic travel a touch, and then lock the center allen set screw on your rocker nut. 1/4 to 1/2 turn is the most common.[/QUOTE.]
This is how i do it most of the time also. Cole |
the way my friend showed me to make sure that you was on the base circle was, exhaust open you set the intake and intake close you set the exhaust. i just find it easier to do it that way, then the way the manual says to do it.
| 400 sbc has a reputation for wearing | spinn | Engine | 10 | 11-19-2010 01:58 AM |
| $4,557.99 for SBC 400 Parts/Machine Work | DTL504 | Engine | 35 | 04-03-2006 05:36 PM |
| 400 SBC Steam Hole Crack | ezobens | Engine | 5 | 03-20-2006 07:28 AM |
| Opinion on 400 SBC Build Up. | ezobens | Engine | 17 | 02-08-2006 12:37 PM |
| Critique my SBC 400 Combo | DTL504 | Engine | 24 | 11-30-2003 05:37 PM |
