SBC 406/421 build advice needed for a 58 Suburban
Hi Folks,
I need some help with our SBC engine build. I’m not new to engines, done several rebuilds but it’s been original spec mostly and never a Chevy engine. It’s been Cadillac V8, Ford V8, Volvo, VW etc and the last time we made any serious engine build for power was well nearly twenty years ago, and that was a VW Beetle 2.3liter turbo making the ¼ mile in 10.69. It was an all original full body, interior, chrome etc 1958 Beetle except for engine and box, real wolf in sheep’s clothing. Now we have a 58 Suburban and well the 283 aint up for the task of an Autobahn stomper scaring the living daylight out of Beemers, Bimmers and Benzes. Hence I sourced a SBC 400 (2 bolt main), and modded the frame to take a Jag IRS with 2.88 posi final drive. The 400 will be coupled to a overdrive box, but I’m not sure yet which one, the goal is 2000 rpm at 70mph and that it should be able to do 150mph. This is a sleeper setup, so a few things are more or less set in stone. 1: Will have original Chevy script valve covers which doesn’t have oil filler or breather holes 2: The 400 will get machined / tricked at the rear to be able to hookup a 283 breather pipe 3: Intake needs to be able to be machined to take a 283 oil filler pipe. It can’t be a super high riser, somebody should be able to get fooled that it’s original at a quick glance. 4: It will have a TBI EFI controlled by MegaSquirt II (possibly III), TBI is a 900cfm Holley 4-port, with 4 injectors (12R-11157B) 1 3/4" throttle blades. I have a 670cfm too but my guess is that it’s way too small. 5: It will have a dual snorkel Pontiac GTO 455 69-72 air cleaner; big nice stocking looking and it will hide the TBI. 6: Will have short WP since I want to look stock for 58 i.e. dyno/alt mounted with original brackets on the drivers side, A6 compressor* mounted with original (well Corvette/Chevelle 65-66) brackets on passenger side, and finally PS pump mounted low on the drivers side. 7: Likely having 2.5” ram horn ala Corvette early sixties, they look the same on the outside as the 58 ram horns on the Burb 8: Will have a small body Megasquirt controlled HEI dist from http://davessmallbodyheis.com/ -- i.e. a stock 58 dist with modern interior and computer controlled ignition map 9: Everything will get painted factory.. :). I’m not building a street and strip engine. Sure I might take a test doing the ¼ mile but that is maybe once or twice during the time I will have the Burb. This engine needs to be streetable and produce loads of torque all the way from say 2000 to 6000 rpm, that is kind of why I went for a 400. Want to have that good feeling you get in a big cube engine. A feeling just getting whisked away from standstill effortlessly without really flooring the pedal, but merely touching it. It’s speed as and the ability to overtake like the car was on fire that is of high importance. Remember it will be a highway/Autobahn warrior ;). Since it’s going to be driven in Europe it can run on 100 octane pump gas (that is about 95 octane in the US due to differences in how octane is measured), I would although prefer to drive on 95 octane (about the same as 91 octane in the US) since that is about 30 cents cheaper per gallon, mind you we pay nearly $8 per US gallon over here – and yes it sucks big time!! If we start with the top end things where a lot easier before simply not much to choose from, I’ve also forgot loads and kind of need your views of what I should go for. Been looking at heads, and if you don’t want to go for cheapo ProComp head, the main stuff looks to be costing about 800 – 1400 assembled depending if you go iron or alu. This is for non CNC ported, but figure I could light porting, matching etc our self since we done that in the past. Looks like runner of about 210 – 225 should be sufficient for a 406 – 421 (depending if I stroke or not). I’m interested in hearing your view and arguments of what heads to go for, around the price bracket mentioned above, likewise what intake to match it with. This assembly aint going to be stressed as an explosive street and strip engine will. Hence is it wrong to think we can go for cheaper parts on non critical parts i.e. lifter and rockers. From experience a breakdown there will not be catastrophic, compared to a breakdown in the rotating assembly. Thinking a retrofit roller cam, with ProComp hydraulic roller lifters (~$120), and ProComp roller rockers, thinking shaft but then there is not much stress on this engine so maybe not warranted to have them. Don’t know what ratio to go for although, well it’s a cam question and here is where I really need advice. What cam should I go for? Need some god advices of what roller to go for? And if I don’t go roller what flat tappet would you recommend? I know that the 2.5” ramhorn might hamper the setup quite severely, but how much will in hamper it? I’m going for a relatively free flowing 3” exhaust, dual the whole way back and with a cross over pipe. I’m also contemplating having exhaust dump vales such as the once sold by quicktimeperformance.com. That way I could just dump out the exhaust without any mufflers at ¾ gas or above i.e. overtaking. Ah yes it would be nice with a good recommendation of what timing gear (type of mechanism) to go for and what model/brand to set for. Here I want good stuff since if this breaks it will get expensive. Well good doesn’t mean expensive just reliable and does the job, and if necessary adjustable (depending on cam). In regards to the rotating assembly I can see us going stock with 0.030/0.040” overbore just. Well of course blue printed, good quality stuff and so on but in all essence stock. However I feel that going internally balanced would be of great advantage, likewise getting better stuff would provide for an engine that will last. So I’m thinking going (forged) internally balanced crank, and I think also going from 3.75” to 3.875” stroke since the price is the same anyways. If I understood it correctly using 6” Scat H-beam stroker rods and you can still go with stock cam base circle and it would only require minimal if any modification of the block (correct me if I’m wrong). It would be nice to get your opinion on what crank and rods to use and your view why. Piston wise I’m contemplating forged or hypereutectic, forged is not that much more expensive but all small expensive in an engine build adds up. Reason why I think hypereutectic might be enough is that; we will never shoot it with nos, nor will we rev it like idiots. Anyways what is your thoughts, what to go for and why? Remember we are in recession so as everyone else we aren’t made of $$ ;). Really big thanks in advance for everyone reading my post and possibly giving advices. Dyna *The compressor might be the newish pro6ten. Still kind of like the old A6 better since it looks just massive :)…. |
Ah forgot to say, yes the 900cfm TBI is probably a bit large.. around 750 - 850 would probably been better...
Cheers Dyna |
A few ??'s.
What HP/TQ are you hoping for? Does the Jag IRS have 2.88 gears? If so an OD Trans may not be needed. OD Trans ratios: Trans--------1st-----2nd-----3rd----4th Gear TH200-4R----2.74---1.57----1.00----0.67 TH700-R4----3.06---1.62--- 1.00----0.70 4L80E--------2.43---1.49---1.00----0.75 I'd shy away from ProComp Roller Lifters & Rockers. Some of their Aluminum Heads are Ok, the ones with larger 215cc or so Intake runners. These are 2 SBC406 builds ChevyHiPerformance did a while back. Very torqy builds. Either of these with a nice Roller Cam would produce much more HP/TQ than these Flat Tappet builds below. The Impersonator I, w/Vortec Heads. http://www.chevyhiperformance.com/te...que/index.html The Impersonator II, w/Aluminum heads. http://www.chevyhiperformance.com/te...ild/index.html I was going to suggest an old Aluminum GM 70-72 LT1 type Intake as they have the provision for the Oil fill tube but, the prices have gone crazy. :rolleyes: They're basically like a Edelbrock RPM Intake. http://www.collectorcarsforsale.com/...0497685800.jpg |
Hi
Thanks for your answer. A Jag IRS from a V12 XJS 1981 and later all come with 2:88 rear end with LSD. Since I actually have a 89 XJS V12 as my daily driver I know this one revs about 3000 rpm at 70mph with 215/60-15 tires, if memory serves me right (not with the car at present). The tires I will use for the Burb will be 235/70-15 so you’re right I might not need an overdrive. I have a 700-R4 but also a 3speed with OD. Afraid that the 3-OD box might explode although. Preferably I would like to still have a manual box on the tree so to say, suggestions welcomed. I don’t really aim for a specific TQ/HQ numbers but rather the result. The more the better but I don’t want a high reving unstreetable machine. At 5500 rpm this brick should be able to do 150mph in 1:1 gear with be 235/70-15 wheels. I’m pretty sure I need a ton of power for that. I think 475+ HP is the bare minimum when you consider weight and most importantly front area of the Burb. So what is that nice roller cam :), in your view? How much more would it produce compared to the Impersonator II - beside I would not lower the comp since I will drive on 91 (US) octane, and even possibly 95 (US octane). The AFR head especially the CNC once are a tad expensive too, and 421 might need bigger runners.. Hmm food for thoughts.. Why would you shy away from their rollers/rockers have you heard about a lot of failures? The issue with their heads form what I hear is casting quality which is very hard to see, while machined stuff is easier to check for faults and coming failures (the rockers looks like they are machined out of billets). A Edelbrock performer RPM (7101 and 7104) actually has provision for the oil tube you only need to machine it in there since it’s not there strait out of the box. Hence don’t think there is a need to go for the 70-72 LT1 intake unless I got something wrong.. Sincerely Dyna Quote:
Use this Calculator & you'll see which gears you'll need for the 70mph & 150mph and at what rpm they'll be reached>> http://www.f-body.org/gears/ For 70mph @2000rpm you need about a 2.40 final gear ratio but, at 150mph you would only be turning 4300rpm. I figured this with a TH700R4, 3.42 gear and 235/70/15 tire. Comp has a free Dyno download to play around with different Cams>> http://www.camquest.com/ All SBC Cam operating ranges are stated using 350ci engines so the Cam's operating/rpm range will be lower with a 406ci engine. It's very difficult to Spec a Cam, I'd go to several Cam sites and fill out their spec sheet for best results. Lunati, Comp, Isky etc.. There're over 100 Dynoed engine combos here>> http://ryanscarpage.50megs.com/combos1.html I would not go cheap on the Valve train. Pro Comp, Proform etc.. Rockers & Lifters look cheaply made. I haven't searched to see if PC has had problems but, have read many problems with ProForm Rockers. I'd use Scorpion Rockers and Lunati, Morel or Isky Lifters. You're correct, I hadn't noticed the machinable Boss on the Eddy RPM Intake. |
Hi
Thanks again for your answers. I kind of figured the 3sp would explode, question is what manual would work and still having the "shift arms" on the side so you can still hook it up to the column shifter on the Burb. I kind of want to avoid going auto if I can. If I was forced I probably go with building my T700-R4. Was playing along with the program over at camquest, and a 280XFI HR13 would produce well over 400 ftlb between 1500 and 7000 rpm with a peak of 550 at 4500 and 545HP at 5500. That was with large headers although. The ram -horns will take a lot of that away - scary amount nearly... but then you don't really know what manifold the dyno prog think is std. Could probably go with a hotter cam if it's what you say it's done for a 350. What I mainly was fishing for was peoples opinion, it's easy to do the fill in stuff at various companies but that never gets as good as somebody that is really good at cams. After all lunati probably gets zillions of requests everyday. Lets see if someone actually have used their lifters or rockers and have any view of it. Sincerely Dyna Quote:
| All times are GMT -6. The time now is 05:14 PM. |
