SBC 406 Help/Validation on low Vacuum Reading @ Idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 10:46 PM
Hi
I am needing a little validation on a SBC build. I tuning on an 88 S10, and have a steady 8" of vacuum at 950 -1050 rpm. The cam is fairly large solid flat tappet. The specs are below. I think I am OK, but would like some opinions.
S10 weighs 3100 with driver
SBC 406 = 9.81 compression - pump gas motor
Eagle Crank
Scat 5.7 Rods
SRP 21cc dish pistons
Pro Comp 190 heads (milled to 60cc) bowl blended and gasket matched to 1206 (.100 long push rods)
Solid Flat Tappet 250/260 @ 50, 562/585 lift w/1.6 rocker
Shorty Headers, 3" exhaust
10" 3800 Stall
4.30 Gear
Air Gap Intake 1" spacer
Holley 750DP, Pro Form Main Body
AFR @ Idle 13.8-14.1
Ignition- Accel (Total Timing 36 @ 3500)
Old 01-01-2013, 01:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Give it as much initial timing as it needs- and it will want a lot (20 degrees-plus). Limit the mechanical timing to keep the total from being too high. Depending on how much initial you now have you might pick up a little vacuum, but the vacuum you have now isn't bad at all for that cam and displacement.
Old 01-01-2013, 05:06 AM
Thanks for the reply, I believe it has 14 advance built in the distributor.
cam, pro comp, sbc 406, vacuum
Low vacuum at idle danzigs Engine 12 03-19-2012 09:23 AM
Vacuum too low at idle? 406 bug Engine 17 10-02-2008 03:39 PM
Low Vacuum Reading, Need advice glg97 Engine 7 10-12-2006 02:15 PM
Ported Vacuum Reading at Idle? JohnTN Engine 29 11-09-2005 04:41 PM
Poor Idle- Low Vacuum Coleman396 Engine 2 06-05-2003 05:39 AM
