Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc 408 small chamber heads for more compression
Old 06-20-2013, 05:49 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
everything I posted is what you need first.as you can see techinspector reiterated the cylinder head issue.The pipe length on the primaries and tube diameter do not look like they are for high performance engines?
Run it as it is,probably sneek into the 11s if the car weighs 3000 pounds.Get some MPH runs and weigh the car,maybe Im wrong and that engine makes more power than I think it makes,,,
